Ribbon
The ribbon allows you to quickly access tools and standard functions, and is located at the top of the Inspire workspace.
![](../../../images/figures/inspire/ribbon.png)
- Use the File, Edit, and View tabs to access menus containing standard functions (i.e. Undo and Redo; and Cut, Copy, and Paste).
- Use the Geometry, Structure, and remaining tabs to access tools organized in icon groups. Icons may provide access to several different tools, and hovering over an icon may reveal additional satellite icons.
Note: You can also create a custom ribbon containing tools that you frequently use.
