Variables
Create and assign variables to parameterize a model. This allows you to quickly iterate and compare design concepts by tweaking the values of the variables.
Variables can applied to a variety of CAD and properties available in tools such as Sketch, Geometry, Implicit, and Motion. You can also specify dependencies between the variables, which will create links between variables.
Manage Variables Using the Variable Manager
Use the Variable Manager to edit variables, create new variables, and import or export variables in .csv format.
On the Geometry ribbon, select the Variables tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools.The Variable Manager is displayed.
You can do the following:
To Do this Notes Import variables from a .csv file Click
. The required format is name,expression,type,comment where type can be l (length), a (angle), unitless, velocity, acceleration, ang_velocity, ang_acceleration, damping, stiffness, torsion_stiffness, torsion_damping etc. You can find available unit types by exporting a .csv file; all available units are written in the .csv as comment. Note: By default, when you import variables, they are merged with any existing variables. To clear existing variables on import, in the Variable Manager dialog box, from the hamburger menu, turn on Clear Variables on Import.Export variables to a .csv file Click
. Delete one or more variables - Select one or more variables.
- Click
Add a new variable - Select an empty Name field or
click
enter a name, and then press
Enter. Important: The Name field may not be left blank. A variable’s name may not be a math operator, numeric value, mathematical constant, reserved Python keyword, or a unit specifier. The name may include underscores (_), but no spaces or other special characters. - In the Value/Expression
column, enter a numerical value, or specify a
dependent relationship between variables, e.g.
OtherVariable*2. Basic math
operators (+,-,/,*) and standard Python mathematical
functions are accepted.
Inspire automatically populates the Result field.
- Optional: In the Comments column, enter any relevant notes.
If you specify units for a Length variable, e.g. 1.0 cm, then Inspire will express the Result in the selected Display Units, e.g. 10 mm. You can use trigonometric functions in Expressions. The input value must be unitless or angle. If it is unitless, the value of it is interprented as radians. For example, X = pi/2 (unitless) and Y = 10*sin(X) or X = 90 deg and Y = 10 * sin(X) or Y=10*sin(pi/2) or Y=10*sin(90 deg)
A variable’s Expression may not reference itself.
Circular dependencies, e.g. where the Expression for L1 refers to L2, the Expression for L2 refers to L3, and the Expression for L3 refers to L1, are not supported.
Edit a variable Select the field you wish to edit and enter the new information.
- Units are automatically assigned based on context. If no units are specified for a new length variable, units are assigned based on the Unit Selector’s current setting. Hundreds of unit types are supported. Derived units result from the combination of the base units (e.g., kg*m/s^2 will result in Newtons).
- Trigonometric, inverse trigonometric, hyperbolic, and inverse hyperbolic functions are available.
Apply a Variable to Parameterize your model
Apply a variable to parameterize your model. Variables can be created on the fly from a tools where f(x) is present .
You can apply existing variables and add new ones via the microdialog in various tools.
In the tool’s microdialog, click the f(x) icon.
Figure 1. Example of a microdialog with a variable field
- In the dropdown menu, select Add Variable to create a new variable based on the dimension in the text field, or select the name of an existing variable.
- Click Apply to apply the variable to the construction feature.
- You can also create a variable by entering a new name and expression in the
microdialog’s text field, for example:
Variable1=50 - In addition, you can also create a new variable based on an existing
variable, for example,
Variable2=Variable1*0.5.
