System Requirements
A list of supported operating systems and minimum requirements for hardware and memory.
Windows
- Operating System
- Windows 10 (64-bit)
- Memory
- 16 GB of RAM (higher recommended)
- Graphics Hardware
- OpenGL 3D graphics accelerator compatible with OpenGL 3.3 or higher
- Video Recording
- Any GPU can be used to record animated GIFs.
MP4 recordings will require an NVIDIA Quadro P series (or RTX) or newer GPU with a driver version of 537.70 or higher.
Please refer to the certification hardware list here:
Linux
Inspire is supported on Linux, except for the Print3D tab and the Porosity check on the Manufacturing tab. Remote job submission is supported on Linux.
- Operating System
- Red Hat Enterprise Linux 8.4 (64-bit)
- Memory
Additional Information on Driver Installations
The NVIDIA Driver Update recommendation is to use the Custom installation option and select the Perform clean installation option to validate that there are no conflicts in DLL/drivers.
- Number of simultaneous jobs. Use of a workload management middleware like Altair PBS is highly recommended to ensure optimal and dedicated usage of the CPU resource.
Typical node configuration is based on dual CPU socket processors.
It is extremely important to populate all the memory banks on the motherboard.
In Hybrid mode, it is recommended to set a number of MPIs that is a multiple of the number of sockets and then set the number of OpenMP in a way that number of MPIs x number of OpenMP equals the number of physical cores.
- Hyper-Threading (HT) may increase performance by around 10% on single node. In this case, the recommended setup is to run 2 OpenMP per MPI, with a number of MPIs that matches the total number of physical cores on the node. On multinode systems, it is better to not use HT.
