Import Thea Materials
Import Thea materials into the Render Library.
Important:
- Some mappings may be the incorrect size when imported. To resize maps, use the Texture Positioning tool.
On the ribbon, select the Rendering tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools.The Render Library is displayed.
- Select the Materials tab.
- Under Material Library, right-click User.
Click Create Package.
- Enter a name for your package.
Right-click the package, and then select Import
materials.
Browse to the folder containing the Thea materials.
Tip: Use the All Files filter to show the .mat files, if they're not displayed by default.
Select one or more .mat files and click OK to import
them.
Thumbnails of the materials are displayed under the user package (depending on the file size, this may take a few minutes).
- Optional: Assign the Thea materials to categories.
