Stack-up
The Layer Stack menu shows PCB’s physical stacked information will be used for Signal Integrity analysis.
From the menu bar, click Layer Stack dialog opens.
. The
- Coating: Conformal coating material applied to protect the top and bottom signal layers
- Dielectric: Dielectric layer between two conductor layers. Multiple dielectric layers can be placed next to each other
- Signal: Etched signal layer. Core signal layer when microvias are used.
- Micro Signal: For boards using microvias. Micro signal layers are made on both sides of board.
- Microvias are used for connecting micro signal layers or connecting a micro signal layer and the first core layer.
- Power: Power plane layer
- Ground: Ground plane layer
- Floating: Floating conductor plane layer
Often the top and bottom widths of etched conductor trace cross-section are different, resulting in a trapezoidal cross-section shape.
PCB trace etching effect can be defined. The value of etching difference can be
typed in after double-clicking and the etching surface direction can be defined by
clicking .
