NC Pin
The NC Pin DFE rule checks for the NC pin connectivity.
- Item: Input item name.
- Component Group: Select target component group to check NC pins.
- Except Pins: Enter exception pins signal name to exclude NC PIN check.
- Pin Type: Select pin type to check NC pins.
