Create Frequency Multi-loadcase
Use frequency multi-loadcases to run multiple frequency response analyses with common modal results.
- On the Main Menu toolbar, select .
Specify the modal results to which the analysis is linked.
The modal solution must exist in the current design study.
- Specify the frequency span upper and lower limits.
- Specify damping using Rayleigh damping coefficients or Modal damping.
- Create Frequency Function.
On the workbench toolbar, select .
The new loadcase appears in the Project Tree. You can apply loads in each individual load cases.
