Run SimSolid on Linux
The Linux version of SimSolid works without any user-interface and is meant to run jobs on HPC clusters.
Note: To access the SimSolid user-interface, use the Windows
version. An SSP is required to submit jobs on Linux clusters.
- Use the installer to install SimSolid on any Linux machine.
Once the installation is successful, you can use the command line below to run
SimSolid jobs.
Commands to use in the .js file to execute SimSolid jobs in batch:<installation folder>/altair/scripts/SimSolid -s <Path to .js file>/<filename>.js -p <path to SSP file>/<SSP filename> -l <path to log file>/log.txt
The above script performs a series of actions namely - opens an SSP file, initializes the solution, runs all the analysis, and saves the SSP by appending _solved to the original file name. It is also set to run the jobs using 24 cores.// open project Project.open({ file: '%1%.ssp'}); //Set number of logical cores Project.setOptions({ numOfCoresToUse: 24 }); // initialize solutions Project.initializeSolutions(); // solve all analyses Project.solveAllAnalyses(); // save project Project.save({ file: '%1%_solved.ssp'});
