2024
Solved verification models.
View new features for SimSolid 2024.
Discover SimSolid functionality with interactive tutorials.
Interfaces that support SimSolid output file format.
Information about treatment and properties of geometric entities in SimSolid.
Summary of available functionality for defining the properties and behavior of parts in the model.
Connections are used to define the association of different regions of interest between parts in an assembly.
Create an analysis for your project.
Boundary Conditions available for SimSolid.
Run analyses and view a variety of results in SimSolid.
Design studies allow you to quickly evaluate and compare the structural performance from different design scenarios.
The purpose and format of the SimSolid verification problems document.
Learn how to access and download required model files.
Test No. VS01 Find tip deflections of a cantilever beam when subjected to extension, shear, and twisting loads.
Test No. VS02 Find tip deflections of a twisted cantilever beam when subjected to shear loads.
Test No. VS03 Find tip deflections of a curved beam when subjected to in-plane and out-of-plane loads.
Test No. VS04 Obtain the displacement at the center of a simple supported thin plate for concentrated load and uniform pressure load.
Test No. VS05 Obtain the displacement at the center of a clamped thin plate for concentrated load and uniform pressure load.
Test No. VS06 Determine the maximum axial deflection and axial stress at the mid-length for a tapered solid bar.
Test No. VS07 Find bending stress at fixed end for a cantilevered plate subjected to a vertical shear load of 120 lbs.
Test No. VS08 Find the maximum stress of a plate with a hole.
Test No. VS09 Find the maximum Z displacement for a curved cylindrical dome.
Test No. VS10 Find the stress concentration in a filleted notch.
Test No. VS11 Find the tip displacement at the free end of a thick, doubly curved beam.
Test No. VS12 Find Sx stress in the notch and top face of a notched plate.
Test No. VS13 Find the max displacement and stress for a pinned beam with load at the midpoint.
Test No. VS14 Find the maximum principle stress at the skew plate center at point E.
Test No. VS15 Find maximum normal stress for two configurations of a filleted bar.
Test No. VS16 Find the critical compression load at which the cantilever beam buckles.
Test No. VS17 Find the stress concentration in a grooved shaft.
Test No. VS18 Find the stress concentration in a plate with eccentric hole.
Test No. VS19 Find the stress concentration in a filleted notch when torque is applied.
Test No. VS20 Find the stress concentration in a plate with semi-circular holes.
Test No. VS21 Find the tangential edge stress in an elliptic membrane.
Test No. VS22 Find outer surface tangential stress for a cylindrical shell.
Test No. VS23 Find displacements in a hemispherical shell.
