Qualify the Working Directory of Jobs
The working directory is the directory from which the job is submitted. For the job to execute correctly, the working directory must exist on the remote host. Directories that are not reachable by all machines in the network should be avoided; this can cause jobs to fail.
- The directory matches one of the strings in the property
NC_VALID_DIRECTORIES
.To accept all directories, use the following rule:% nc cmd vovprop set -text 1 NC_VALID_DIRECTORIES ". /"
To check the value of the property, use the following command:% nc cmd vovprop get 1 NC_VALID_DIRECTORIES . /
- The directory has been marked with a file called .vnc.
- The directory has a logical name; its name is represented by a string that begins with a dollar '$' sign, such as ${HOMES}/john.
WARNING:
The path to the current directory is not 'LOGICAL',
i.e. it does not begin with a '$' sign.
EXPLANATION:
The current directory
/export/scratch/john
may not be a valid directory path for all hosts in the network.
OPTIONS:
(1) Continue.
By choosing this option, you assert that the path
is valid everywhere. If it is not, the job is likely
to fail, because the remote host cannot reach
the current directory.
This option causes the creation of a flag file
called .vnc which has the purpose of
avoiding the repetition of this question for this
directory and its subdirectories
(2) Abort.
Ask your NetworkComputer administrator to
change the equiv.tcl file to define the rules that
give a logical name to the current directory.
Please reply: [1,2] >
