Submit a Single Job
- Use an environment snapshot.
- The default resource list is the vovarch of the machine that submits the job.
- The name of the log file is automatically computed.
Run a Job, No Specifications
% nc run sleep 30
Resources= sun5
Env = SNAPSHOT(vnc_logs/env912488489.csh)
Command = sleep 30
Logfile = vnc_logs/20020704/150449.6528
JobId = 00002539
Run a Job, Environment Specified (-e)
% nc run -e BASE sleep 30
Run a Job, Environment and Resources Specified (-r)
% nc run -e BASE -r linux -- sleep 30
Resources= linux
Env = BASE
Command = sleep 30
Logfile = vnc_logs/20020704/150515.6528
JobId = 00002544
Run a Job, Environment and Resources Specified, Limited Verbosity (-v)
# Control verbosity: print the jobId only.
% nc run -v 1 -e BASE -r linux -- sleep 30
00002579
# Running a job, environment and resources specified, limited verbosity and wait for job to finish (-w):
% nc run -w -v 0 -e BASE -r linux -- sleep 30
