Log Files
Log Files
The standard output from the pre- and post-commands is saved in log files. The location of the log files is determined by the value of the environment variable NC_LOGDIR. If NC_LOGDIR is not set, the files are stored in the directory ./vnc_logs, relative to the current launch directory.
[goetz@goetz1 ~/testrundir]$ pwd
/home/goetz/testrundir
[goetz@goetz1 ~/testrundir]$ ls
vnc_logs
[goetz@goetz1 ~/testrundir]$ ls -a vnc_logs/
. .. 20210726 .precmd.000083865.log .precmd.000083885.log snapshots
The log files are created with zero size if the pre- and post-commands redirect all the output of the files. At the end of the job, if these files are zero length, they are automatically deleted to reduce disk space overhead.
.precmd.$jobID.log
.postcmd.$jobID.log
nc run -pre "myprecommand > @JOBLOGDIR@/@JOBID@_pre.out" -l path/to/an/existing/directory/mycommand.out -- mycommand
nc run -post "mypostcommand > @JOBLOGDIR@/@JOBID@_post.out" -l path/to/an/existing/directory/mycommand.out -- mycommand
