Parse a Debug Log
A need may arise to manually parse a debug log to gather denial and/or utilization data. This can be helpful in debugging problems with the data obtained from the file, or with parsing the file itself.
For parsing FlexNet Publisher debug logs in particular, be sure to first review Manage Data from Different Origins. A number of caveats exist when importing debug logs. It is important to be aware of these ahead of time to set expectations, and better plan for how data will be utilized.
- Are the debug logs static or regularly rotated?
- Are you attempting to parse the log for checkouts as well as denials?
- Do you need to merge checkouts from multiple origins within the same time frame?
- Do you wish to access imported log data on the same graph/report as sampled data?
- Do you need capacity information for checkouts loaded from debug logs?
- Do you need to access imported data live, or just for archive purposes?
Operation
% vovproject enable licmon
- Altium: ftlm_parse_altiumlog
- CodeMeter: ftlm_parse_codemeterlog
- Dassault: ftlm_parse_dslslog
- FlexNet Publisher: ftlm_parse_debuglog
Click each link above to learn the arguments required and options supported for the command.
