Sample a License Server
The Monitor CLI provides the ability to manually sample a license server to gather availability and utilization data. This can be helpful in debugging problems with the connectivity to a license server, or the data that is returned from the license manager status command.
Operation
To manually sample a license server, regardless of the license manager type, first setup the CLI:
% vovproject enable licmon
Click the links above to learn the arguments required and options supported for each command.
