How do I Manage My Licenses and License Servers? (Admin)
Set up Agents. Agents centralize management. You can update, maintain and add and subtract licenses from a central point. Monitor can be configured to monitor hardware and process information if agents are configured on the machines you wish to monitor. Agents can be configured and controlled remotely from the Monitor server if certain conditions are met. In most cases, you will configure an agent to run remotely. You can learn more about how to set up agents by clicking on Agents.
