File System Monitoring
Similar to the Hosts List page, the File System page shows information about the various file systems that are present across all of the hosts that are being monitored.
This can be useful in identifying file systems that are low on available disk space. This page color-codes file systems, which provides easy to use file system identifiers that requires little disk space.
![](../bank/../../images/monitor/file_systems_list.png)
Figure 1. File Systems Page: Host Information
- Fs Id
- The file server ID.
- File Server Host
- The file server host name.
- File System
- The type of file system.
- FS Type
- The file server type.
- Clock Offset
- The difference between your machine’s clock time and the file server’s clock time.
- Quota
- The disk quota is a limit set by a system administrator that restricts certain aspects of file system usage on modern operating systems. The function of using disk quotas is to allocate limited disk space in a reasonable way. If it shows “no,” then no quotas are set on your machine.
- Total Space (MB)
- Total available space on the file system.
- Free Space (MB)
- Total space available left for use.
- Free Space (%)
- Percent of available space on the file system.
