In the scenario of this example, a license does not utilize
FlexNet Publisher or another dynamic license management solution, but
does require a tool to run only on one specific host. In this example, the tool is
spice
, the host is
pluto
, and the license is
for two concurrent instances of spice. Following are the steps to correctly handle
this constraint:
- Choose a name (in the form
name
or
type:name
) to represent the node locked resource (such
as License:spice_pluto
) and a name to be announced to the
users (such as License:spice
). In this way, it is hidden to
the users that the spice license is locked to a given node. Also, if there
is an upgrade to a floating license or multiple node-locked licenses, that
can be carried out without having to announce it to the users.
- Add the following lines to the resources.tcl file:
vtk_resourcemap_set License:spice UNLIMITED License:spice_pluto
vtk_resourcemap_set License:spice_pluto 2 pluto
% nc cmd vovproject reread
- Let the job declare that it requires the resource
License:spice
; use option -r in
nc run as
shown below:
% nc run -r License:spice -- spice -i chip.spi
