Selection Rules
Selection rules are used to create sets and to perform queries.
- The name of the field, which is required. The name of the field is case-insensitive and may contain extra underscores. For example, ISJOB, IsJob and is_job are all legal names for the field ISJOB.
- An operator on the field. Refer to the list of Operators.
- A value. This part is interpreted as an integer for boolean and integer fields, or as a string for string fields. The value may contain spaces or other special characters if it is enclosed in double quotes (see Examples of Selection Rules, below). Spaces in a value may also be entered if they are preceded by a backslash ("\") character. Operator and value can be omitted, in which case they default to !=0 for numeric fields and !="" for string fields.
A special case is also supported where the name of a field can be passed by itself. This will query for objects that contain the field, and where the field's value is non-zero (for numeric fields) or non-empty (for string fields).
idint<5000 | idint>10000 & isjob
idint<5000 | (idint>10000 & isjob)
(idint<5000 | idint>10000) & isjob
isjob & status==FAILED,INVALID
This rule
is equivalent
to:isjob & (status==FAILED | status==INVALID)
isjob status~A,B
will match any job with "A" or "B" in its
status field and does NOT attempt to match the string "A,B". If you wish to use a
comma in a regular expression, enclose the expression in quotes. In this example you
would use isjob status~"A,B"
. Selection rules that accept integer values will also accept timespecs; for example
"isjob autokill>10m
" would select all jobs with an autokill set
to greater than 10 minutes.
Selection Rule | Explanation |
isjob==1 |
Select all jobs |
isjob |
Select all jobs (equivalent to
"isjob!=0 ") |
!isjob |
Select everything except jobs (equivalent to
"isjob!=0 ") |
not isjob |
"isjob!=0 ") |
IS_FILE and db!=FILE |
Select all files which are not in the database
FILE |
status==RUNNING |
Select all nodes whose status is RUNNING |
status==RUNNING,VALID |
Select all nodes whose status is RUNNING or VALID |
status!=RUNNING,VALID |
Select all nodes whose status is neither RUNNING nor VALID |
status!=RUNNING and status!=VALID |
isjob status==INVALID |
Select all invalid jobs |
isjob duration>300 |
Select all jobs that have lasted more than 5 minutes (i.e. 300 seconds). |
isjob command~~aa |
Select all jobs with a command line containing the string
aa ; the ~~ operator is used for case
insensitive match. |
isjob age<600 |
Select all jobs completed less than 10 minutes ago. |
isjob & age<600 |
isjob AND age<600 |
isfile name~ccc |
Select all files with name containing ccc .
isjob inputs<2 status==INVALID |
Select all jobs that have fewer than 2 inputs and are invalid. |
isjob AND (inputs<2 OR
status==INVALID) |
Select all jobs that have fewer than 2 inputs or are invalid. |
isjob (inputs<2 |
status==INVALID) |
isjob inputs<2 | status==INVALID |
Select all jobs that have fewer than 2 inputs, and all nodes (including non-jobs) that are invalid. See notes on AND/OR precedence, above. |
isfile status==VALID age>=600
name~xxx |
Select all valid files older than 10 minutes whose name
contains the string xxx . |
isfile status==VALID age>=10m
name~xxx |
isjob tool==gcc resources~diskio
duration>10 |
Select all jobs that use the tool gcc and require the resource diskio and take more than 10 seconds. |
isjob status~A,D |
Select all jobs that have either "A" or "D" in their Status fields; see notes on commas in regular expressions, above. |
isjob & status~"A,D" |
Select all jobs that have the string "A,D" in their Status fields. |
isjob & status~[A-Z]+A[A-Z]+D |
Select all jobs that match the regular expression "[A-Z]+A[A-Z]+D" in their Status fields (e.g. FAILED, INVALID). |
isjob status::inv* |
Select all jobs whose status fields start with "inv" (case-insensitive). |
isjob and status:inv* |
Select all jobs whose status fields start with "inv" (case-sensitive). |
isjob status!::inv* |
Select all jobs whose status fields do not start with "inv" (case-insensitive). |
isjob AND command!^"sleep 60" |
Select all jobs whose commands do not contain the string "sleep 60" (case-sensitive). Note that spaces are allowed in quoted values. |
isjob AND command!^^sleep\ 60 |
Select all jobs whose commands do not contain the string "sleep 60" (case-insensitive). Note that spaces are allowed if preceded by a backslash ("\"). |
Selection Rules and Incompatible Fields
isjob name~xxx
is to select all jobs in the trace, because the
predicate isjob
is true for jobs and false for files, while the
predicate name~xxx
is true for all jobs because the field
"NAME" is incompatible for jobs.autoflow
. # Look for skipped jobs
isjob ISAUTOFLOW==1
