User Interfaces
You can access and manage the FlowTracer subsystem in multiple ways. This table explains the four different user interfaces. Mix and match which ones you use.
User Interface | Description | Features |
Command Line Interface | The Command Line Interface is the set of programs you can run from the shell command line. These programs form a rich set of operations with command line parameters that provide detailed control of each task. Some tasks such as creating projects can only be done using a CLI command. | Enables automation of work. Commands can be run from a script. |
Graphical User Interface | The Graphical User Interface is a custom application client using the client/server architecture. You use this program to have a clean, visual way of accessing the dependency graph, so you can control and manage the tracing of jobs. The graphical interface gives you a convenient way to do ad hoc activities for monitoring and controlling the processing. | Interactive. Offers full and immediate control. |
Browser Interface | The browser interface is a web based application built into
the FlowTracer system. The FlowTracer system provides the web server and web
application as part of the standard installation. The server and
application is accessed by a URL to the host. This web
application provides a form based interface to access and manage
the FlowTracer processing using the browser
as your client program. The browser based web application includes links to the documentation. |
Easy to use. Part of the normal install. |
All About Tcl | Tcl is the language of choice for writing scripts to manage
the FlowTracer system. The FlowTracer system provides a useful set of Tcl
extensions that can be used by custom written Tcl scripts to
access and manage processing. You can write Tcl scripts that have full control over FlowTracer processing, including the development of new shell command line commands. |
Programmable, extensible. Most useful to advanced users. |
