vovtsd (Tasker Service Daemon)
The program vovtsd is a daemon written as a Tcl script that runs using the VOV vtclsh binary. This daemon can be used also to start various types of agents on any type of Windows or UNIX machine.
In Windows, vovtsd is started from the command line and then runs
in a Windows cmd
shell. Each vovserver
connects to vovtsd via TCP/IP to start the vovtasker process.
vovtsd
This utility listens for requests to launch taskers for various projects, but always for the same user. The requests typically come from vovtaskermgr.
Usage
vovtsd: Usage Message
VOVTSD: Vov Tasker Service Daemon
USAGE:
% vovtsd [OPTIONS]
OPTIONS:
-v -- Increase verbosity.
-h -- Print this help.
-debug -- Generate verbose output.
-help -- This message.
-normal -- Start a normal daemon (for current user)
-expire <TIMESPEC> -- Exit from vovtsd after specified time.
-user <user> -- Specify the user that should be impersonated.
vovtsd computes the port number by
hashing the user name.
-port <n> -- Specify port to listen to.
EXAMPLES:
% vovtsd -normal
% vovtsd -port 16666
% vovtsd -user john -port 16000
Start a Remote vovtasker with vovtsd
To use vovtsd on Windows, follow these steps:
Run vovtsd as a Different User
The vovtasker started by vovtsd will run as the user running vovtsd. If you need for this to be different from the user logged in at the keyboard and screen, you have several options.
C:\temp> runas /user:domain-name\username cmd
