Make Board Paneling Tutorial
Make Board Paneling is a function to modify the data designed with a single sub board into an array type to use manufacturing related features such as Metal Mask Manager, Mounting Emulator, Block JIG Generator, Router-Machine JIG Generator, and so on.
Make Board Paneling using PDBB
- Launch PollEx PCB.
- From the menu bar, click and open the PollEx_PCB_Sample_r<revision number>.pdbb file from C:\ProgramData\altair\PollEx\<version>\Examples.
From the menu bar, click .
The design file is saved as a *.pdbb file. The Make Board Paneling dialog opens.
Create array number one.
- In the Make Board Paneling dialog, enable the Route checkbox.
- Enable the Board Figure checkbox.
- Enable the Board Outline checkbox.
- Under Placement, select Move To and enter 0 for both X and Y.
- Click Add Board.
Array number one is registered in the array list. -
Create array number two.
- Enable the Mirror checkbox.
- Select Y Mirror.
- Under Placement, select Move To and enter 137.2 for X and 0 for Y.
- Click Add Board.
Array number two is registered in the array list. -
Create array number three.
- Select X Mirror.
- Under Placement, select Move To and enter 0 for X and 140.8 for Y.
- Click Add Board.
Array number three is registered in the array list. -
Create array number four.
Figure 3.
Create Panel outline.
In the Define Panel outline section, you can define the Panel Board outline.
Figure 4.
Make Board Paneling using Gerber Data
Import Gerber data.
When the Metal Mask Gerber of the panel board is prepared, the sub-boards can be automatically calculated by selecting the component pad of the design data and the pad object of the Gerber data.
The Make Board Paneling dialog opens. The design file is saved as a *.pdbb file. If the file is not saved, the Make Board Paneling cannot be used.
Figure 5.
Create Array List by selecting CAD and Gerber data.
- In the Paneling Object Definition section of the Make Board Paneling dialog, enable the following checkboxes: Route, Board Figure, and Board Outline.
- In the Placement section, enable the Object Select checkbox and select CAD Object.
- Select the Pad to be used as the reference from the CAD data.
Figure 6.
Select pad based on Gerber data.
Use the Get Panel Outline from Gerber option to define the Panel Outline.
