WinProp API Examples
A number of small examples is available that illustrates how to use the WinProp API.
Each WinProp API example consists of the following files:
- CMakeLists.txt
- The CMakeLists.txt file is used to set up a Microsoft Visual Studio solution with all dependencies (linked libraries).
- .h
- The .h is the header file. It is a text file that contains the class and function definitions.
- .cpp
- The .cpp file contains the source code. It is a text file that contains the implementation of the class and function definitions.
1 where
%FEKO_HOME% refers to the location of the Altair Feko installation, for example
C:\Program Files\Altair\2024.1\feko.
