Results of iron losses multiparametric computation
Computation results
The multiparametric computation of iron losses gives the following results
I/O Parameters
I/O Parameters called "Inst_iron_losses_i" is stored in the tree, in the area
It represents instantaneous losses on the region(s) versus time, geometric and I/O parameters.
Post-processing iron losses
It is possible to use the previous I/O parameter in order to display iron losses computation.
For instance, it is possible to display a 3D curve of iron losses versus two parameters (time or geometric parameter or I/O parameter) via the menu f()").
. The I/O parameter called "Inst_iron_losses_i" which contains loss values can be accessed in formula editor (Click on "Export iron losses
It is possible to export iron loss values via the menu
:For this:
- Select "Inst_iron_losses_i" I/O Parameter that has been created during iron loss computation
- Choose the export format as well as the name of the file
- Select the intervals corresponding to the computation intervals
- Select the type of values to be exported. For example:
- Average value (on transient interval). Remark: this is a statistical mean.
- Current value
- Click on OK
