Add a Flange Operation
Simulate a pad holding a blank against the bottom die of a model while a wiper die deforms the blank into the desired shape with a flange.
From the Tryout ribbon, click the Add
operation icon.
From the Add Operation window that appears, select the
Flange.
The Flange operation is added to the Tryout ribbon. -
Click the Flange operation.
The default tools are displayed.
Configure the tools for the Flange operation.
Figure 1. Model Setup for a Flanging Simulation
