Geometry
New Features
  • The Split/Unsplit/Stitch and Suppress tools have been merged into one Split/Stitch tool for ease of use and accessibility.
  • A new workflow has been added for the Align/Project tool to support all the options on the guide bar for ease of use.
Enhancements
  • A new Parasolid method has been added for splitting surfaces with lines along with an option of extending split to surface edges.
  • Surface imprint with lines has a new method to imprint lines by extending lines to surface edges.
  • The extend line functionality has been improved and the same line can now be extended more than once.
  • The scaling workflow has been improved by adding origin node and optional system selectors on the guide bar.
  • The Stitch tool now has guide bar selections to select specific entities like points, surface edges, or surfaces to be stitched.
  • A new Variable Manager for Sketcher is supported with all the variable types.
  • Robustness improvements have been done in various tools like Quick Edit, Align, Split, Defeature, and Sketching tools.
