Altair HyperMesh
New Features
- New Mass Balance Workflow
- The Mass Balance tool can be used to automatically distribute masses on nodes or properties, to match user-defined target mass and CoG of selected properties.
Enhancements
- Unit Conversion
- Support of /BEGIN card attributes and engine keywords has been added.
- Contacts
- Description of /INTER attribute Istf in the Entity Editor is updated to the description used in HyperCrash.
- Model Checker
- New Warning, Constraints with unresolved main or secondary entity, to detect /MERGE/RBODY with unresolved element ID or unresolved node ID has been added.
- Keywords Support
- Support of /FAIL/TSAIHILL has been added.
Resolved Issues
- TETRA10 and BRIC20 solid elements are now selectable in /TH/BRIC keyword Entity Editor.
- The issue for rigid body collectors when reading /SUBMODEL with ID offsets has been fixed.
- The issue in detecting /SENSOR/HIC and /SENSOR/DIST_SURF as empty has been fixed.
- The issue when reviewing /INTER/TYPE11 has been fixed.
- The issue in reading attributes of /PROP/BEAM and /PROP/TRUSS due to non existing Beamsection has been fixed.
- The export issue for attributes gap_max_m and gap_max_s in /INTER/TYPE25 has been fixed.
- The segmentation error when reviewing /MERGE/RBODY with unresolved node ID referred has been fixed.
