Connectors
New Features
- Connector XML Export Options
- You can now specify the Connector XML format during export into the solver deck of the model.
Enhancements
- Connector Group Removal
- Connector Groups have been removed. Any existing models and files will automatically be migrated to direct Part Ownership. The Group details are added as Metadata.
- Guide Bar Updates
- The selectors for the connector creation workflows have been updated:
- No keyboard shortcut selection is required to change between
nodes/node lists.
- A new "+" selector has been added to confirm the creation of a point line, line, or area connector.
- Locations/location lines have been added.
- This allows the removal of box selection vs snapping
options for nodes in the
menu.
- Aero lines have been added.
- Create a point connector at the center of the line.
- Any connected lines will be treated as the diameter value.
- Any
menu
changes will now reflect on the connector.
nodes/node lists.
- Miscellaneous
- Changing from an attachment to connectors in idle will select any connectors that are using the attachment.
Resolved Issues
- Sorting by ID in the Connector Browser now ignores the type.
- Connector color mode update issues when reloading models have been resolved.
- Direct Property Assignment no longer assigns the property to the component as well as the element.
- Solid Outer Face now supports Hexa elements.
- Adjacent robustness has been improved for connectors on the surface of a solid mesh.
- Adding multiple significant points no longer causes issues during realization.
- Enabling the Tria option no longer causes a segmentation fault during realization.
- The Attachment tool no longer crashes when exiting.
- Large projection issues with Seam Quad realizations have been resolved.
- Reversing line connectors with retain nodes no longer removes significant points.
- Systems assignment with Huth Point connectors has been improved.
