Meshing
Enhancements
- Cross Extend
- FE geometry is now supported for Cross Extend.
- Stitch
- The CAD and FE tab has been removed from the
menu. - Features
- FE geometry support has been added for 2D and 3D hole detection.
- Normals
- FE geometry surface adjust using reference element/vector now results in
better output.
- Normals adjust using reference element uses connectivity method.
- Normals adjust using vector uses direction method.
- Extrude
- Hex functionalities have been moved under Extrude.
- New Geometry Organization
- In the Geometry section of Preferences, a "New" create in option has been added.
