Altair PBS
Launch a Simulation via PBS Access
            - Browse to your PBS Access server and login.
- Click the Jobs menu and select
- Select the nanoFluidX version to be used and enter a Job name.
                Select (or drag-and-drop) the input files to the browser so that they are
                    uploaded.
                Note: It is possible to upload a *.zip file when there are many files or if the file size is large. This will be automatically extracted at runtime.
- Select the number of GPUs to use and click Submit job.
Test PBS
When Altair PBS is used as the scheduler on the target system, a test run of nanoFluidX could be carried out through PBS. For further
                details on setting up PBS for use with GPU resources, refer to the relevant PBS
                    documentation.
        Note: The exact steps may change depending
                    on the PBS settings on your particular system.
- Log in as a regular user. Do not use root user.
- Run system tests without using PBS, following steps 1 through 4 outlined in the Single Node section.
                Copy dambreakcase fromdemo_casesto the location of choice:<LOC>: cp <INSTALL_DIR>/ altair/hwcfdsolvers/nanofluidx/linux64/demo_cases/dambreak <LOC>/dambreak
                Prepare the environment in your PBS script by adding one of the
                    following:
                - Single
                        node:nfxmpirun_pbssinglenode -np 1 $nFX_SP -i dambreak_3D_H300_dx0p005_wt.cfg -m 10
- Multi
                        node:<INSTALL_DIR>/altair/hwcfdsolvers/nanofluidx/linux64/ set_nFX_environment.sh multinode
                        PBS must produce a HOSTFILEwhere each node is repeated once per GPU on each node.
                        Set Xequal to the number of GPUs across all nodes.
- Single
                        node:
                Launch nanoFluidX in your PBS script by adding the
                    following:
                - Single
- Multi
                        node:nfxmpirun_pbsmultinode -np X $nFX_SP -i dambreak_3D_H300_dx0p005_wt.cfg -m 10
- Single
                        node:
                The test run is successful when the message Finished (reached maximum steps)appears at the end of the PBS output file.Note: Simulation time may vary.Figure 2.
