Meshing
Enhancements
- Geometry organization enhancements:- The Shapes, Lines, Solids, and Sketch tools now adhere to the Create in options under preferences.
- For the Extrude tool, the Create in options for hex has been removed
                                locally from the  menu. It
                                adheres to global preferences. menu. It
- Robustness has been improved for FE geometry stitching.
- Panel Mesh has been renamed to Map Mesh.
Known Issues
- For , there is a segmentation error when you attempt to manually create features like flanges, fillets, and logos.
