Task Manager
New Features
- Process Editor
- The new Process Editor tool provides an interactive and easy way to create
                        and modify a Task Manager process (the XML file). From the Developer ribbon,
                        select .Figure 1.
Enhancements
- Two new columns have been added to the Task Manager:- Active column
- Select the check box to activate/deactivate a task.
- Run column
- Click the play button to directly run the selected task.
- Property categories within the Task dialog are collapsible.
- Task Manager API:- The goToTask method supports both a task object or tag as an input argument.
- A new active attribute has been added to Task objects.
- The position of the task window (eeposition attribute of the XML file under the process item) can now be set to “undocked”, “left”, or “bottom”.
