Altair HyperMesh
New Features
- FMVSS201 U Tool
- The Upper Interior Head Impact tool is now available in the Radioss Interface. Refer to the Safety Tools release notes for more information.
Enhancements
- Radioss 2024 Profile Support
- Support of Radioss 2024 profile has been added.
- Updated Keywords for Radioss 2023.1
- New attributes or attribute values have been added to the following
                            keywords for Radioss 2023.1:- /FAIL/FABRIC
- /PROP/TYPE14
- Updated Keywords for Radioss 2024
                            keywords to Radioss 2024:- /PROP/TYPE9, /PROP/TYPE10, /PROP/TYPE11, /PROP/TYPE16, /PROP/TYPE17, /PROP/TYPE19, /PROP/TYPE51
- /PLY
- /STACK
- Deletion of Position Entities
- When deleting a Position entity, you are asked to choose if the impacted
                            nodes have to be moved to their original position, or, if they have to
                            be maintained in the transformed position.Figure 1.
- Contact Penetrations Check
- The Penetration Check tool now has a new and simplified workflow. Refer to the General release notes.
- Performance Improvements
- Performance is improved in the model export process, when a high number of nodal masses (/ADMAS Type 5) are defined in the model.
Resolved Issues
- The issue when creating /ADMESH/GLOBAL keyword has been resolved.
- A correction in the model import process related to /GRNOD/BOX keyword has been made.
- A correction in the model import process related to ANIM/SHELL/IDPLY keywords has been made.
- A correction in the model export process related to /H3D/LSENSOR keyword has been made.
- Second order tetra elements are now selectable in /TH/BRIC.
