Position the Car
Use the Move tool to position the car inside of the wind tunnel.
- In the Model Browser, click the top-most assembly to select the entire car.
From the Home group, click the
Move tool.
The Move tool will initially be positioned at the centroid of selected entities.Figure 2.
Click a graphical manipulator then do one of the following:
- Drag the graphical manipulator to translate or rotate entities in the selected direction(s).
- Enter a precise value in the microdialog and press Enter.
To Do This Translate along an axis Click the X, Y, or Z arrow. Figure 3.
Translate along a plane Click the XY, XZ, or YX plane square. Figure 4.
Translate freely in 3D space Click the origin of the Move tool. Figure 5.
Tip: Use the icons in the microdialog to align the tool to a part or the global axes.Rotate around an axis Click a curved arrow. Figure 6.
Rotate freely Click
at the tip
of the X, Y, or Z arrow and drag. In the external
aero setup environment, an axis line appears and the
unresolved rotation is prompted on release.Figure 7.
Position the front end of the car at a certain distance from the inflow.
A similar technique can be used if a certain ride height, distance of the fender lip to the ground or underbody to the ground needs to be modeled. A reasonable positioning in the z direction, upwards, is when the wheels are slightly penetrating the ground of the wind tunnel.
Figure 9.
