Fan
Assign a part as a fan component.
fan = vwt.Fan(partId)Parameters
- partId
- Part or list of parts
Attributes
- axis
- Axis of rotation
- center
- Wheel center
- speed
- Rotational speed
- diameter
- Diameter of cylindrical volume
- length
- Length of cylindrical volume
- offset
- Offset distance of solid revolution from fan parts
- refinementLevel
- Mesh refinement level of rotating volume
- interfaceRefinement
- Enable interface refinement for Overset volume
- interfaceRefinementLevel
- Interface refinement level
Methods
- rotatingVolume(type, partId)
- Assign part as an MRF or Overset volume
- rotatingCylinder(type)
- Create a cylinder as MRF or Overset volume
- solidRevolution(type)
- Create a solid revolution around fan as MRF or Overset volume
- splitParts()
- Split intersecting fan parts with rotating volume
