Select Material Properties
Ti-17 titanium alloy
350WT steel
7010 T7 Al alloy
7075 T6 Al alloy
7050 T7451 Al alloy
2324 T7 Al
A36 steel
| Property | Value |
| Elastic Modulus (MPa) | 1.90538E+05 |
| Elastic Poisson's Ratio | 0.3 |
| Cyclic Strain Hardening Exponent | 0.1656 |
| Cyclic Strength Coefficient (MPa) | 893.9 |
| Plane Strain Fracture Toughness (MPa(m1/2)) | 75 |
| Kt Compression | 3.5 |
| Characteristic block size Rho* (m) | 5.0E-05 |
| Glinka's P ratio correction factor | 0.1421 |
| Yield Strength | 319.403 |
| Comma-separated list of Glinka's coefficients | 1.571952E-16,7.7532202E-14 |
| Comma-separated list of Glinka's coefficients | 7.2070257,4.745437 |
