Load history headers cannot be renamed. Blocks of the load
history file can be renamed.
Add Time Data Loads
Time data loads are available
for the Time Series loading type.
Click the Load Map tool.
The Load Map dialog opens.
Select Time Data from the Channel Type drop-down menu in
the top-left of the dialog.
In the Choose file field, click and browse for
files.
Accepted file formats are:
.rpc/.rsp, .csv,
and .dac
Click to add the load
case(s).
Optional: Edit the maximum and minimum values of the loads.
Optional: Click to view a plot of the load.
Add Constant Amplitude Loads
Constant amplitude loads are
available for the Time Series loading type.
Figure 3.
Select Constant Amplitude from the Channel Type
drop-down menu in the top-left of the dialog.
Click to add the load case.
Tip: Click in the Channel Name field to rename the load case.
Optional: Edit the maximum and minimum values of the load.
Figure 4.
Add Block Loads
Create a block series of various amplitudes. Each block can have "n" number of
cycles.
Block loads are available for the Time Series loading type. Figure 5. Sample CSV Format
Figure 6.
Select Block Loading from the Channel Type drop-down
Click .
The Block Load dialog opens.
Specify a name for the block load.
Specify the number of blocks to create then .
Edit the values for Max Amplitude, Min Amplitude, and Cycles.
Different blocks come together to make a block sequence, which is used for the
damage calculation.
Click Create.
Figure 7.
Tip:
Use the and icons to import and
export block load .csv files.
Select a block and click to delete it.
To exclude a block from the load, disable its checkbox.
Add Eigen Value/CMS Loads
There are two types of modal
participation factor channels available: Eigen Value (via a .pch
file) and CMS (via an .mrf file). Both are available for the Modal
Superposition loading type.
Figure 8.
Select Eigen Value (pch) or CMS
(mrf) from the Channel Type drop-down menu in the top-left of
the dialog.
In the Choose file field, click and browse for a
*.pch/*.mrf file containing modal
participation factors.
case.
Add Input PSD Loads
There are two types of Input PSD
channels available: Phase & Magnitude and Real & Imaginary. Both are available
for the Random (Input PSD with FRF) loading type.
Figure 9.
Select Input PSD: Phase & Magnitude or
Input PSD: Real & Imaginary from the Channel Type
*.csv file containing PSD vs frequency data.
case.
Figure 10.
Note: Extrapolate specifies the handling method for y-values outside the
specified range of the x-values of the input PSD curve. If Extrapolate =
True , If an x-value input is outside the range of x-values specified on the
table, the corresponding y-value look up is performed using linear
extrapolation from the two start or two end points. If Extrapolate = False,
If an x-value input is outside the range of x-values specified on the table,
the corresponding y-value is equal to the start or end points, respectively.
loads.
Figure 11.
Note: Any load channels that you import are specific to the channel type. If you switch
the channel type, the channel window is cleared/updated.
Add Constant Loads
Constant loads are available for
the Sine Sweep loading type.
Figure 12.
Select Constant Load from the Channel Type drop-down
case.
Edit the scale value.
This value is used to apply a constant scale across all frequency response
stresses.
Add Variable Scale Loads
Variable Scale loads are
available for the Sine Sweep loading type.
Figure 13.
Select Variable Scale from the Channel Type drop-down
.csv file containing Frequency vs Scale data.
This data is used to apply variable scales across frequency response
stresses.
