User Defined Material XML
Materials created by user are saved to UsrDefMaterialDB.xml.
The HyperLife Material XML file should be contained within the <HyperLifeMaterials> root tag, as shown below. The tag has an attribute: version.
<HyperLifeMaterials version="2024.1.0.8-HYLB_3094">
  <MATERIAL ID="0" NAME="Sample_Material" MAT_TYPE="steel" REFERENCE="" SOURCE="">
    <MATPROPERTY
	UNIT="MPA"
	ELASTIC_MODULUS="207000"
	UTS="600"
	YIELD_STRENGTH="250"
	POISSONS_RATIO="0.3"
	STSGRD_CONSTANT="stsgrdconstants"
	STSGRD_aG="0.5"
	STSGRD_bG="2700">
    </MATPROPERTY>
    <SN
	N_CRVS="1"
	SN_CURVE_TYPE="Ratio"
	INPUT_METHOD="slopeintcept2"
	STRESSTYPE="FTGMAT_STSTYPE_AMP"
	NC="600000.0"
	NFL="1000000.0"
	XY_SE="0.01">
      <CRV
	RATIO_MEAN="-1"
	SN_FATIGUE_STRENGTH_COEFFICIENT="1208"
	SN_FATIGUE_STRENGTH_EXPONENT="-0.13300000000000001"
	SN_ENDURANCE_LIMIT="1000000"
	SN_FATIGUE_STRENGTH_EXPONENT2="-0.108"
	SN_FATIGUE_LIMIT="150"
	SN_STANDARD_ERROR="0.29999999999999999">
      </CRV>
    </SN>
    <EN
	INPUT_METHOD="estimate"
	EN_FATIGUE_STRENGTH_COEFFICIENT="1002.000"
	EN_FATIGUE_STRENGTH_EXPONENT="-0.095"
	EN_FATIGUE_DUCTILITY_COEFFICIENT="0.35"
	EN_FATIGUE_DUCTILITY_EXPONENT="-0.69"
	EN_CYCLIC_STRAIN_HARDENING_EXPONENT="0.11"
	EN_CYCLIC_STRENGTH_COEFFICIENT="966.000"
	EN_REVERSAL_ENDURANCE_LIMIT="2e+8"
	EN_STANDARD_ERROR_ELASTIC="0.300"
	EN_STANDARD_ERROR_PLASTIC="0.300"
	EN_SHEAR_STRENGTH_COEFFICIENT="0.0"
	EN_SHEAR_DUCTILITY_COEFFICIENT="0.0"
	EN_SHEAR_STRENGTH_EXPONENT="0.0"
	EN_SHEAR_DUCTILITY_EXPONENT="0.0"
	EN_COEFICIENTFKP="1.2"
	EN_COEFICIENTNKP="1.0"
	EN_MAX_STRAIN="0.02"
	EN_FSPARM="0.3"
	EN_BMPARM="1.0"
	EN_BERGMANN="1.0">
     </EN>
  </MATERIAL>
</HyperLifeMaterials>
The Material XML contains the following major sections:
  • Material
  • Matproperty
  • SN
  • EN
  • FOS
The Material XML supports materials properties from Stress Life, Strain Life, Seam and Spot welds, Factor of Safety and Crack Growth (saved from HyperLife Crack Growth profile.)
MATERIAL Tag
<MATERIAL ID="0" NAME="Mat_SN(1)" MAT_TYPE="steel" REFERENCE="" SOURCE="" TYPE="">
</MATERIAL>
Table 1. MATERIAL Tag Attributes
Element Tag Valid Values Comment
ID
No default
(Integer > 0)
Material ID
NAME String Material name
MAT_TYPE steel, aluminium_alloy, other
REFERENCE String Reference name
SOURCE String Source Name
TYPE
stresslife,
strainlife,
fos
Fatigue module type, supported for backward compatibility, can be skipped in v2024.1 and onwards
MATPROPERTY Tag
<MATPROPERTY
	UNIT="MPA"
	UTS="600"
	STSGRD_aG="0.5"
	STSGRD_bG="2700">
</MATPROPERTY>
Table 2. MATPROPERTY Tag Attributes
UNIT
MPA (Default)
KSI,
PSI
Defines the units of stress values specified
ELASTIC_MODULUS Real > 0.0 Young's modulus.
UTS Real > 0.0 Ultimate tensile strength.
YIELD_STRENGTH Real > 0.0 Yield strength
POISSONS_RATIO -1.0 < Real < 0.5 Poisson’s ratio
STSGRD_CONSTANT stsgrdconstants Stress gradient to be enabled in Fatigue module
STSGRD_aG Default = 0.5 (Real) 𝑎𝐺 value in FKM stress gradient effect.
STSGRD_bG Default = 2700 (Real) 𝑏𝐺 value in FKM stress gradient effect.
SN Tag
<SN
	N_CRVS="1"
	NC="600000.0"
	NFL="1000000.0"
	XY_SE="0.01">
      <CRV
	RATIO_MEAN="-1"
      </CRV>
</SN>
Table 3. SN Tag Attributes
N_CRVS Default = 1, 2,…,n
Single or Multiple curves
Default = 1, highlights a single SN curve and its properties to follow
SN_CURVE_TYPE
Ratio,
Mean,
Haigh
Ratio = Stress Ratio based curves
Mean = Mean Stress based curves
Haigh = Haigh diagrams based on Life
if No. of SN curves = Single,
SN_CURVE_TYPE = Ratio/Haigh only.
INPUT_METHOD
estimate
(estimate from UTS)
point1
(point, 1-segment)
point2
(point, 2-segment)
slopeintcept1
(Slope-intercept, 1-segment)
slopeintcept2
(Slope-intercept, 2-segment)
slopetrans1
(Slope-trans, 1-segment)
slopetrans2
(Slope-trans, 2-segment)
xydata
Haigh Diagram supports only xydata input method
STRESSTYPE
FTGMAT_STSTYPE_AMP
FTGMAT_STSTYPE_RNG
Defines the interpretation of the defined SN curve.
Amplitude / Range
NC
Default = 600000.0
Real > 1000.0
Supported for XY Data SN curve / Haigh
Fatigue transition point. After this point, fatigue strength is offset by the surface correction factor. Before this point, fatigue strength is proportionally reduced.
NFL Default = 1.0E+8 (Real > 1.0E+5)
Endurance limit. Number of cycles at which damage can be considered zero.
XY_SE
Default = 0.0 (Real > 0.0)
Standard Error of log(Stress)
Note: For Point segment, the values to converted to required options in the HyperLife session.
Table 4. SN <CRV> Tag Attributes (based on input method option: Estimate/2 Segment/1 Segment curves)
CRV - Section listing SN properties for the selected curve
RATIO_MEAN
Default = -1
Real
Stress Ratio of the SN curve
SN_FATIGUE_STRENGTH_COEFFICIENT No default (Real > 0.0) Fatigue strength coefficient. It is the stress range intercept of the SN curve at 1 cycle on a log-log scale.
SN_FATIGUE_STRENGTH_EXPONENT Real < 0.0
The first fatigue strength exponent.
The slope of the first segment of the SN curve in log-log scale.
SN_ENDURANCE_LIMIT
No default
No default (Real ≥ 1000.0)
In one-segment SN curve, this is the cycle limit of endurance
SN_FATIGUE_STRENGTH_EXPONENT2 Real < 0.0
The second fatigue strength exponent.
the slope of the second segment of the SN curve in log-log scale.
SN_FATIGUE_LIMIT Real ≥ 0.0, or blank Fatigue Limit. No damage occurs if the stress range is less than FL
SN_STANDARD_ERROR
Default = 0.0
(Real ≥ 0.0)
Standard Error of Log(N).
Table 5. SN <CRV> Tag Attributes (based on input method option: Single/Multiple XY Data)
ID 1,2….n SN curve ID from the list of curves
RATIO/LIFE ( for Single SN curve)
RATIO/MEAN/LIFE ( for Multiple SN curves)
Ratio
Default = -1 (Real)
Mean
No Default (Real)
Life
No Default (Real > 0)
RATIO = Stress Ratio
MEAN = Mean Stress
HAIGH = Haigh Diagram
NPOINTS Integer Number of points in the curve
Xi Real > 0
Depending on SN_CURVE_TYPE, Xi values can be one of stress amplitude or stress range,
No default
Yi Real > 0
Depending on SN_CURVE_TYPE, Yi values can be life (SN_CURVE_TYPE = LIFE) or mean stress (SN_CURVE_TYPE =RATIO or MEAN).
No default
eN Tag
<EN
	INPUT_METHOD="slope"
	EN_FSPARM="0.3"
	EN_BMPARM="1.0"
	EN_BERGMANN="1.0">
</EN>
Table 6. eN Tag Attributes
INPUT_METHOD
slope
(user defined)
estimate
(estimate from UTS)
No default (Real < 0.0)
b, Fatigue strength exponent.
c, Fatigue ductility exponent.
Fatigue ductility coefficient.
np, Fatigue strength exponent.
EN_CYCLIC_STRENGTH_COEFFICIENT No default (Real > 0.0) Kp, Cyclic strength coefficient.
Default = 2.0E8 (Real > 1.0E5)
Reversal limit of endurance. One cycle contains two reversals.
Default = 0.0 (Real ≥ 0.0)
Standard Error of Log (elastic strain).
Standard Error of Cyclic Stress-Strain curve.
Default = Blank (Real > 0.0)
Shear Fatigue Strength coefficient (τ′f) based on amplitude. This value should be one half of the value defined for tfp on the SN continuation line.
Shear Fatigue Ductility coefficient (γ′f)
Default = b𝑏 (Real ≤ 0.0)
Shear Fatigue Strength exponent (𝑏𝛾)
Default = c𝑐 (Real ≤ 0.0)
Shear Fatigue Ductility exponent (𝑐𝛾)
EN_COEFICIENTFKP
Default = 1.2 (Real > 0.0)
Coefficient value
EN_COEFICIENTNKP
Default = 1.0 (Real > 0.0)
Coefficient value
EN_MAX_STRAIN
Default = 0.02 (Real > 0.0)
Maximum Strain value for Strain-Life Approach. The default value is 0.02 (corresponds to 2% strain).
In multiaxial fatigue analysis, this value is used as maximum allowable strain in the plasticity model. If accumulated strain is greater than this value, HyperLife does not calculate actual damage but assigns a larger value of damage (10.0).
In uniaxial fatigue, 10% of this value (0.2% by default) is used as maximum possible strain amplitude. If strain amplitude is greater than 10% of this value, a warning message will be issued. Actual damage is still calculated.
EN_FSPARM
Default = 0.3 (Real ≥ 0.0)
Constant k for the Fatemi-Socie model.
EN_BMPARM Default = 1.0 (Real ≥ 0.0)
Constant S for the Brown-Miller model.
EN_BERGMANN Default = 1
Constant for Bergmann Model
FOS Tag
<FOS
	FOS_TFLINPUT="Table"
	FOS_TABLE_XVALUES="0.0000000e+00;2.9530000e+02"
	FOS_TABLE_YVALUES="2.2000000e+02;0.0000000e+00"
	FOS_TORSIONAL_FATIGUE_LIMIT="220.0"
	FOS_HSS="0.745"
	FOS_SHEAR_THRESHOLD="15.0"
	FOS_SAFEZONE_ANGLE="25.0">
</FOS>
Table 7. FOS Tag Attributes
FOS_TFLINPUT
Table
Real
Table, Data Entry that defines the intersection points. The X-values represent Hydrostatic Pressure, and Y-values represent Shear.
Real,
Considers TFL and HSS,
FOS_TABLE_XVALUES = “blank”
FOS_TABLE_YVALUES = “blank”
FOS_TABLE_XVALUES,
Hydrostatic pressure
X1,X2,….Xn
FOS_TABLE_YVALUES
Shear Stress
Y1,Y2,….Yn
No default (Real > 0.0 or Integer)
Torsion fatigue limit. A Real or Integer value can be specified.
FOS_HSS No default (Real > 0.0) Hydrostatic stress sensitivity.
FOS_SHEAR_THRESHOLD Default = 0.0 (Real ≥ 0.0)
Shear Threshold for the Safe zone. If the microscopic shear stress is lower than this value, it is considered safe.
FOS_SAFEZONE_ANGLE
Safe zone angle. If the angle of a point in the domain is lower than the Safe zone angle, it is considered safe
