Export Batch Run
Use the Batch Input file to run HyperLife Weld Certification in batch.
The HyperLife batch input XML file should be contained within the
<HyperLifeInput> root tag, as shown below. The tag has two
attributes: profile and version.
<HyperLifeInput version="24.000000" profile="WeldCertification">
</HyperLifeInput>
Note: Batch run xml is not supported for Stress Life and
Regulations - ERRI and IEC.
Input files contain the following major sections:
