LoadMap
<LoadMap>
<LoadType>fixedpoints</LoadType>
<DutyCycleFile>C:/Users/nandar/Documents/Fatigue/WeldRunHistory/dvs1608_Run2_20240124_120458/FixedPts_dvs1608_Run2_20240124_120458.rdf</DutyCycleFile>
</LoadMap>
| Element Tag | Valid Points |
<LoadType> |
File path of the Material csv |
<DutyCycleFile> |
For Fixed points = Range Definition file (RDF) For Constant Amplitude = Duty Cycle (XML) The RDF/XML files are written to Export directory in Weld Run History Example:
Format of RDF and XML duty cycle files
Fixed Point Duty Cycle with 2 events (RDF
file)
#HyperLife Weld Certification Fixed Point Range Definition File
#RANGES
*id ncy LC1 LC2 LC3 LC4 SF1 SF2 SF3 SF4 *Event
1 2000000 4,0 1,0 5,0 3,0 1 1 1 1 *Event_1
4 2000000 1,0 3,0 4,0 5,0 1 1 1 1 *Event_4
#END
Constant Ampltiude Duty Cycle with 2 events (XML
file)
<LoadMapData version="24.000000">
<LoadMap typeofloading="Time Series">
<Channel>
<tabfat Max="1" Min="-1" id="1" type="Constant Amplitude"></tabfat>
<tabfat Max="1" Min="-1" id="2" type="Constant Amplitude"></tabfat>
<tabfat Max="1" Min="-1" id="3" type="Constant Amplitude"></tabfat>
<tabfat Max="1" Min="-1" id="4" type="Constant Amplitude"></tabfat>
</Channel>
<FatigueEvents>
<Event id="2" name="Event_2" repeats="1">
<Fatload LDM="1" Offset="0" Scale="1" resultfile="" sim="0" subcase="1" tabfatId="1" tabfatName="ConstantAmplitude_1"></Fatload>
<Fatload LDM="1" Offset="0" Scale="1" resultfile="" sim="0" subcase="3" tabfatId="2" tabfatName="ConstantAmplitude_2"></Fatload>
</Event>
<Event id="3" name="Event_3" repeats="1">
<Fatload LDM="1" Offset="0" Scale="1" resultfile="" sim="0" subcase="4" tabfatId="3" tabfatName="ConstantAmplitude_3"></Fatload>
<Fatload LDM="1" Offset="0" Scale="1" resultfile="" sim="0" subcase="5" tabfatId="4" tabfatName="ConstantAmplitude_4"></Fatload>
</Event>
</FatigueEvents>
<Fatseq></Fatseq>
</LoadMap>
</LoadMapData>
The constant amplitude loading format is similar to the Duty Cycle format from HyperLife Basic for Time series loading: Load Map.
