Add and Delete Models
In each study, you can add one or more models.
Add Models
Add a model to your study.
- In the Define Models step, click Add Model.
In the Add - HyperStudy dialog, define model settings and
click OK.
- In the Label field, enter a name for the model.
- Select a model type.
Tip: Quickly add a model by dragging-and-dropping a supported model file
directly into the work area of the Define Models step.
Delete Models
Delete models from your study.
- In the Define Models step, select the model in the work area that you wish to delete.
Click Remove Model.
