Load Resource Files
A resource file establishes the basis of the connection to HyperStudy. Information about the input variables and/or output responses are passed through the file.
In the Define Models step, Resource column of the model you are defining, click
In the HyperStudy - Load model resource dialog, navigate
to your working directory and open the resource file.
Note: If you load a file for a Parameterized File model that does not contain parameters, a dialog will appear asking if you would like to parameterize the file. If you select Yes, the file will open in the Editor as a *.tpl file. When you close the Editor, HyperStudy automatically loads the*.tpl in the Resource column, and inserts the file name in the Solver input file column.
