hgtrans control GetIncrement
Gets the current increment between data points to be translated.
HyperGraphTrans Tcl Query
This command gets the increment between data points read from each channel in the input file. Increments greater than one are primarily used to pair down large data sets.
Set hgtrans to translate only every other data point, and then
        verify.
    hgtrans control SetIncrement 2
hgtrans control GetIncrementErrors
None.
Keywords
get increment
