hgtrans control SetStart
Sets the starting data point index.
hgtrans control SetStart index
HyperGraphTrans Tcl Modify
This command sets the index of the first step to read from each channel in the file. It is primarily used to filter out early data points that are not significant. The index is one-based.
- index
- Index must be an integer greater or equal to one.
Context
Cause hgtrans to read everything from a MADYMO file
        called “ANGACC” and save it to “ANGACC.abf”,
        except the first time
        step.
    hgtrans control SetFile "ANGACC"
hgtrans control SetStart 2
hgtrans control SetOutputFile "ANGACC.abf"
hgtrans config SetAllChannelsSelected
hgtrans control StartTranslationErrors
If the starting index is higher than the last data value index present, no data will be translated.
Keywords
set start
