pltIPlot SetCategoryValues
Sets the category values.
pltIPlot_handle SetCategoryValues values
Tcl Modify
This command sets the category values of the plot in a bar chart (these are the labels
        across the x-axis).
    Note: This method is only valid for bar charts.
- values
- A string of inputs for the category values that you want to use. The string has parentheses “ “ around it, and the different category values will be separated by spaces.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot SetCategoryValues "Bob Joe Sally Travis Lisa";Errors
Keywords
Tcl
Bar Graph
Modify
