pltIPlot SetPostDrawProc
Sets the procedure to be used after normal plot drawing.
pltIPlot_handle SetPostDrawProc proc
Tcl Modify
This method is only valid for polar plots. Returns 0 = HW_Success or 3 = HW_InvalidHandle.
- proc
- The name of the procedure to be used.
To set the post-draw
        procedure:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName [myProjectName GetActivePage]
myPageName GetWindowHandle myWindowName [myPageName GetActiveWindow]
myWindowName GetClientHandle myPlotName
myPlotName SetPostDrawProc myPostDrawProcErrors
None.
