poIIsoValueCtrl SetShellLayer
Sets the current shell layer.
poIIsoValueCtrl_handle SetShellLayer layer
HyperView Tcl Modify
This command sets the current layer.
    Note: The scalar storage within HyperView can accept a shell layer or a derived quantity of all shell
          layers (max, min, or extreme).
- layer
- The shell layer label or one of the following derived types:- max
- Stores the maximum value of all layers.
- min
- Stores the minimum value of all layers.
- extreme
- Stores the maximum absolute values of all layers.
Returns 0 if successful, otherwise an error code.
