poITensorCtrl SetDataComponent
Sets the data component for a given component label.
poITensorCtrl_handle SetDataComponent comp_label
HyperView Tcl Modify
This command sets the data component for a given component label.
    Note: Dimension must be
          enabled before setting.
- comp_label
- The data component label.
Returns 0 if successful, otherwise an error code.
