tblITableEditor GetFilledTableSizeColumns
Returns the number of filled columns.
tblITableEditor_handle GetFilledTableSizeColumns
Tcl Query
Returns the number of columns between the most left and right column which contain cells with values.
The following cells are filled in a table:Figure 1.
The variable
$filledColumns
will be “4” (B
-E).set t [hw::GetT]
set activetableHandle [hwi GetActiveClientHandle ch$t]
set filledColumns [$activetableHandle GetFilledTableSizeColumns]
