tblITableEditor GetFilledTableSizeRows
Returns the number of filled rows.
tblITableEditor_handle GetFilledTableSizeRows
Tcl Query
Returns the number of rows between the top and bottom row which contain cells with values.
The following cells are filled in a table:Figure 1.
The variable
$filledNumberOfRows
will be “5” (Row
5-9).set t [hw::GetT]
set activetableHandle [hwi GetActiveClientHandle ch$t]
set filledNumberOfRows [$activetableHandle GetFilledTableSizeRows]
