Reduce a full 3D model with axisymmetric surfaces while accounting for
imperfections.
This is useful in the pre-design thermal analysis of something like turbomachinery
parts.
Since source solids may not be perfectly axisymmetric around a spin axis, this tool
provides a way to imprint some details onto axisymmetric surfaces.
This will delimit region boundaries for the mesh. An algorithm (available in Volume
Reduction) accounts for a volume reduction factor to capture the correct volume while
spinning elements around an axis.
Example Use
In the model below, there are six bosses with pockets. The solid does not have a pure
axis of revolution.Figure 1. Model to Reduce Figure 2. Axisymmetric Surfaces Generated Figure 3. Volume Reduction Factor Applied
